03-14-2024, 03:31 PM | #1 |
Rep 796
Drives: 2010 328ix E91, 2011 128i E82
FS: Tire/Wheel Storage Stand on Wheels & Protective Tire Totes
Schwaben Wheel Storage Rack With Casters and Tire Totes (Covers) - $85 Stack your extra wheels without the danger of scratches and scuffs. This wheel storage rack keeps your wheels spaced apart, and being on locking casters, allows you to easily move the whole set anywhere in your garage or shop at one time. Sturdy steel construction and a wide base means this wheel rack won't tip over. Holds up to 275 lbs - enough for most any wheel & tire set. Fits up to 8½" wide wheels (depending on offset) if using the stacker racks that hold the wheels apart. I did not use those and just let them sit one on top of the other. The strap system (included) is just added insurance to keep everything held down securely and makes it easier to move around the garage. Tire totes also included - fit most tires/wheels. Had been used on C5 Corvette wheels. Located in Newark, Delaware. Here is the rack loaded up (these are not the totes you will get, just to show what it looks like loaded): Unloaded with the straps for securing the wheels: Unloaded with the spacer rack, which I never used, and the totes you will get: A couple of stock photos from the manufacturer:
K9Leader 2010 328i x-Drive, E91 - Space Gray/Black 2011 128i E82 6MT - Crimson Red/Black Last edited by K9Leader; 03-14-2024 at 03:39 PM.. |
