04-10-2024, 05:20 PM | #1 |
Rep 2,347
Drives: 9Y0 Cayenne S
2025 4Runner announced!
Long awaited by 4Runner fans everywhere. Arguably the best vehicle ever designed, manufactured and sold.
https://pressroom.toyota.com/2025-to...eady-heritage/ 2 powertrains: 2.4L 4-cylinder ICE and 2.4L 4-cylinder mild hybrid, both with 8-speed transmission. Last edited by chassis; 04-10-2024 at 06:09 PM.. |
04-10-2024, 05:36 PM | #2 |
Rep 97
Drives: AW G80 6MT
I love the new body style....very much past due by this point. We have one at home and it is a bulletproof reliability vehicle.
04-10-2024, 06:19 PM | #3 |
Rep 14,404
As far as looks go, not bad.
Except for the snorkel. Stop it. I'm looking at you too, moist pea gravel roaming Defenders.
Crazy Diamond
04-10-2024, 06:46 PM | #5 |
Rep 4,080
Toyota is cashing in on all these new models! Looks good, but more importantly, it looks like a 4Runner!
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
04-10-2024, 06:46 PM | #6 |
Rep 1,567
I hope these two bring enough power to this new beast...
"Standard i-FORCE turbocharged 2.4-liter four-cylinder engine produces 278 horsepower, 317 lb.-ft. of torque" "Available i-FORCE MAX hybrid powertrain produces up to 326 horsepower, 465 lb.-ft. of torque"
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (show car) |
chassis6705.00 |
04-10-2024, 07:32 PM | #7 |
How's My Driving?
1110
Rep 998
Are you drunk?
2018 Charger Hellcat
2019 Miata 30th Anniversary 2021 CX-5 Signature 2009 Mazda6 |
chassis6705.00 RM72906.00 pchera0185.00 mjj223.50 Car-Addicted7345.00 DieselDiner489.00 LDT1620.50 VR1641.00 |
04-10-2024, 09:34 PM | #9 |
Rep 999
Can anyone explain to me what's the point of Toyota's 2.4L turbo i-FORCE MAX hybrid powertrain? The gas consumption is the same as the non-hybrid BMW i6 B58 in X5 or even X7, but slower, more complicated, takes more space, can't be plugged-in and requires premium gas. I do get old high MPG and slow 2.5L hybrids, but new i-FORCE MAX hybrid striggle to deliver any MPG improvements compared BMW I6s. Does this make any sense or we are just spoiled by awesome BMW powertrains? Maybe emissions, CAFE?
BTW, love the styling Tacoma/4Runner styling and physical controls. Last edited by Sedoy; 04-10-2024 at 09:49 PM.. |
chassis6705.00 B58-M340iX223.50 |
04-10-2024, 10:40 PM | #10 |
Rep 565
toyota hybrid philosophy is different with the trucks. the hybrid is the power up motor, not for more mpg (get a prius) but for more power. they focus more on qdr and the battery packs are meant to be cheaper and ez replace down the line. they may be less efficient (its a truck/work vs passenger) but 10x more durable, it be nice if they adopted 8hp
chassis6705.00 |
04-10-2024, 11:07 PM | #11 | |
Rep 3,494
I drove a 3.slow 4 runner extensively. Then the higher HP V6 engines starting coming along, much higher compression, much higher rev limits, etc. These were decent for a few years, especially when turbo tech was still extremely laggy and required revving up to 3K to build up any significant power. V8s were kind of the go-to back then, but they are big in the engine bay, heavy and take a lot of gas...at all times. Even as they pumped those V6s higher and higher, up to around 350 in some cars, they still never had the shove of a V8 or modern turbo car. The torque curve tells you all you need to know...it has to rev to 7K or whatever for peak and it's not flat. Now modern turbo engines make full torque around 1300-1500rpm, all the way up through their rev-range. The one in my ZR2 makes 430lb/ft of torque. This also gives cars a good shove down low, since they are making all that torque way WAY before the top of the rev range. Turbo lag with turbos now attached directly to the block where the exhaust manifold basically houses the turbine section, often with twin scrolls and other arrangements, is a thing of the past. Trans tunes and pedal response are different reasons why cars aren't "faster", but having a "normal" and "sport" setting allows them to get the mileage for the testing in the normal setting, and then that better response in the "sport", showing that there's no significant turbo lag. Hybrid is another way to add torque, especially from 0mph. Again, these modern turbos make full torque at ridiculously low rpm compared to old 90s tech and before, but hybrid brings that to the next level. Torque.
04-11-2024, 04:05 AM | #12 |
Rep 18,832
Yeah, thanks, but I'll keep my Gen 6 Bronco with its 2.3L EcoBoost 300 HP and 325 pounds of torque running through a manual transmission.
And the top comes off with just 8 bolts. It's just a more interesting drive. Last edited by Efthreeoh; 04-11-2024 at 05:43 AM.. |
chassis6705.00 |
04-11-2024, 07:17 AM | #13 |
Rep 1,203
Looks killer, but I don't get how it's gonna work out with the Land Cruiser being like, basically the same. Same motors, I think they're the same size, just seems like they are basically the same vehicle.
chassis6705.00 |
04-11-2024, 08:23 AM | #14 |
Rep 1,248
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Finally - maybe the last ones will stop being $50,000 10 years old with 80K on the clock. LMAO!
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
chassis6705.00 |
04-11-2024, 09:00 AM | #15 |
Rep 12,318
Obviously he's not talking about driving dynamics, but in terms of reliability? All day long.
I had a 7 owner 1997 4Runner with over 300k miles and had been in a few accidents according to Carfax. As with all cars I buy, I go ahead and change all the fluids. Turns out the radiator and trans cooler is one unit and the fluids had mixed. When I drained the trans fluid, it looked like strawberry milkshake and I thought this trans was for sure dead. Changed radiator (under $100), added new trans fluid and drove the car for years before I sold it for more or less same price. So yea, I have a soft spot for Toyota trucks/SUVs.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
04-11-2024, 05:32 PM | #20 | |
Rep 2,347
Excellent 4Runner ownership story. And not uncommon. |
04-12-2024, 12:01 PM | #21 | |
Get off my lawn
938
Rep 1,162
Big fan of the rugged looks and reliability of these Toyotas, will be watching intently to see how the gearbox and infotainment setup are reviewed. A 3rd row would be nice in my life |
chassis6705.00 |
